I'm hoping you can follow that link but it's a recent diagnostic of my 2005 merc c class and I'm afraid it's fucked but I have no idea, there are 24 faults most of which are CAN communication I think
Anyone with any advice on any of the codes, fixes or how messed up it is, is greatly appreciated
Thank you
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Welcome to the forum @Damian18 - please take a moment to read the information on the links below. It explains how to use the forums and update your user profile so that your car's details and your location appear on each post below your avatar. This is good information for others to know when trying to help. It also has good information about how the forums are organized and how to use the search feature:
Find your Forum Section, Navigate & Search
Complete your profile.
Some of those could be due to low voltage. I'd recommend clearing them, drive a bit, and then re-scan.
· Outstanding Contributor , SDS Guru
1998 MB E300TD, 1997 MB E36 AMG, 2001 MB E55 AMG. 2011 BMW 335d
Only code that is of any importance is the one in transmission. Speed sensor failure, that will be the cause of limp mode.
Replace the conductor plate, I think you're on 5 speed AT, so it's cheap to do.
Then clear all codes and report back.
