The problem: After engine and head exchange ... OM617 (low miles sedan 617.951 engine into 1984 wagon using the rebuilt wagon head with SLS pump mounting....
With the head off I dropped the timing chain into crankcase, fished it back out after some jimmying the crank back and forth, after installing the head the the valve timing was off by four teeth, 36 degrees rotation at cam 72 degrees rotation at crank .. this equals four sprocket teeth .... I jumped cam sprocket (moving cam sprocket counterclockwise relative to marks) by four teeth which brought cam timing back to perfect relative to the crank. Simple enough. Then doing that same operation with IP pump timing should bring IP timing back to perfect. Logical? That is what I did. It is possible to lift the timing chain off the IP timing device, and rotate by four teeth, let the chain back down to the IP timer being meticulous about marking sprocket teeth and chain to reference where things were and where you want them to end up. Now the drip timing procedure suggests start of delivery is off the scale, maybe 100 degrees BTDC ... as though I didn't correct the IP device as the crank to cam synchronization by 72 degrees (72 plus 25 = 100) .... but I did. This engine was purchased used and I'm unable to verify timing prior to this.
It starts and runs, requires heavy accelerator foot until its warm, has low power with abnormal amount of a loud "knock", (too much combustion BTDC, ie its self defeating...?)
Is this logic regarding bringing IP timing back to correct without removing IP??
Thanks in advance....
John Freeman
[email protected]
John Freeman
[email protected]
