2002 e320 4matic Wagon
Replaced the shocks. Almost done but with the new shock, I can either get ball joint attached with the lower fork unattached or vice versa. I can't get them both attached. If I attach the ball joint, I can't lift the fork high enough, or push the arm down low enough to insert the bolt. But if I do the fork first, I can't get the arm up and over the top of the ball joint. If I put the upper nut on first, I can't get the horizontal part of the ball joint to go in. The first side was fine, but this side won't go. I should say that I have the stabilizer bar off.
