Be sure the entire master cylinder reservoir is completely full, including the half closest to the firewall. That's often tripped up many an SL owner doing this job.
Are you using a pressure bleeder? If so, go with the high end of the recommended pressure and pump it back up as needed to maintain that pressure. Be sure to fully depress the pedal at least once to get the air out of the master cylinder as you begin each separate circuit.
Remember, too, that there's a lot of fluid to replace and that the pressure bleeder only provides a tiny fraction of the pressure the system operates under. The new fluid has a long way to go and a lot of resistance getting there.
Patience. Best of luck, bud.
Good road,
Good road,
