If it aint broke dont fix it, learnt that the hard way today!
I set about trying to clean the cap and rotor today because of rough idle. So I took each of the caps off and scraped the green stuff off as much as I could and used a soft brush to get rid of the rest.
I then opened the right rotors, gave that a quick clean, and very lightly sanded the contact on the rotor.
Tried to open the left rotor but one of the screws has rusted and as I tried to turn it the top bit just fell off (its a beru rotor and the screws are like soft material). And now i guess theres no way I can get that screw out?
I then put everything back together and started it up, seemed a little rough to start with, then when accelerating sounded even rougher and some noise was coming from the left cap and rotor (the rotor which I couldnt open due to screw falling off). Then on idle, it slowly it cut off. I started again and at idle cut off again. 3rd time and now dosent even start up, no sign of it!
Sorry for long explanation, can anyone help?
