At movement it is disconnected ABS
On the screen appears red EBV
By pressing a brake there is a warning sound
Can because of the bearing?:confused:
G270cdi 2004
I think ABS warning is yellow. Red could be brake pads maybe or brake fluid. If you have some more details...
brake pads and brake fluid in norm. At first it is disconnected ABS then the screen becomes red and peeps EBV by pressing a brake pedal
In service have told that probably is the bearing on one wheel
The gage incorrectly reads out the information and consequently there is a failure in system EBV
is it possible? Because of the bearing all system goes mad and is disconnected?
Something is doubtful:cool:
Zotye Auto 1.5T T600 2016
You need to read out the diagnostic fault codes using appropriate diagnostic test equipment, try a local indie/specialist and then let us know what the codes are, we can then help you to fix it.
