Bought the 98 S320 65k miles back in 07/2010. It had exisitng slight leak from timing cover and got that fixed. Later on, i discover there is still slight leaks (size of dime every night), the ind. mechanic says it's from head gasket. He said I can drive like that and take care of the problem later if it gets worse. So, I did that for the last 3 months and about 2500 miles.
The oil leak has got worse for the last couple weeks and 2 days ago noticed the temp would go over usual 90 degree over to 110 briefly before coming back down gain. I was just thinking aboutaking the car to my mechanics yesterday on the way to work, and then I notice smoke coming from the rea of the car on the highway. The temp slowly creeping past 90 again, so I slow down to 60 mph and watching it closely hoping I can make it to my mechanics about 5 miles away. Oil pressure is still normal at 3 at that time. Unfortunatel white smoke coming from the front too just when I was exiting the highway, oil level suddenly drop down to 0 too. So I pull the car to the gas station at the exit and called my mechanics. He's like 2 miles away from where I was and he said I can go get some oil and filled the coolant after let it cool down and drive to his place.
Idid all that and the car drove normally (no seize), unfortunately right before I got to the garage, the coolant warning light and smoke all came up again.
He told me this morning that blown gasket caused engine over heat, coolant and oil leak extensively. The coolant leak so fast because the connection was bown off due to the high pressure from broiling coolant.....
So, he is now in the process of taking the head off, and depends on the condition of the head, best case is he can resurface the head and replace the head gasket, worst case is that the head is beyond repair, then I would have to find a used or rebuilt engine to put in. He quoted me $800 to $3000 depends on which case after he take the head out.
Thanks for reading through this long description. I would appreciate any advice as far as what to watch out for. (whatelse should I make sure he check and replace at the same time? Should the ead is no good and I have to get a motor, what would you advise me to do)
Thanks.
Thanks.
