I have no dash warning lights when the ignition is turned on and the car is not charging. Checked all the fuses relays and curcit tested the altinator wires getting two lives from the larger two wires i should be getting an earth from the smaller wire but there is no power live or earth HELP!!!!!!
2002 CL55 AMG, 1993 190E 2.3L, 2004 SLK320 Sport
Check the ovp relay and fuse on it!
http://www.thebenzbin.com/mercedes-hard-start.html
This might help!
Good Luck!
2006 S500 AMG Wifes Rig Hillbilly Girl 02 ML320
Also "DOUBLE CHECK" >ALL< your fuses if a certian one takes a dump things like that happen to your dash!! They might LOOK good but looks can be decieving!! Take it from one who had it happen to him!![:(!][:(!][:(!]
Smokie
