1 - 13 of 13 Posts
2011 E550C
Hi, I am new to BenzWorld so forgive me if I bring up questions that are buried deep in an old thread somewhere.
I purchased a CPO 2011 E550C this May and I have been informed that the brakes, both pads and rotors need to be replaced. I have driven it for 6k miles.
Is this normal?
I have also had an abysmal time with the Sirius. This is my third MB and it is the first time I have had serious satellite problems. I think they changed the antenna when it first happened but there has been no improvement. What have any of you done with this issue?
Gear shifting seems erratic sometimes as well. Once I thought I was hit from behind, but it was just a rough gear change. There is also an engine smell coming through to the cabin when all the air is off. Do you think it is related? BTW, I was told that I am confusing the CPU that runs the gear changing, but I can't seem to confuse the C250 they have loaned me.
Let me know what you think BenzWorld.
2014 E63 S-model, 2014 Acura MDX, 2009 Infiniti G35x
You can reset the transmission adaptation, there is a simple process you can go through in your car to do this -- someone can get you the sequence. This may resolve your transmission issue once it re-learns your driving style.
How many original miles on the car including your 6k miles? brakes and rotors wearing out are a product of the driver's braking style.... this can vary from car to car.
I have not had issues with sirius in my 2k14 .. they need to address this in your car.. you can also have sirius re-set the signal to your car, you can call them and you'll have to have the car out in the open outside a garage and you'll need your Sirius radio ID, channel 0 or channel 1 on your radio. Call their 800 number, it may solve your connection issues
2011 E550C
Thanks for your reply. I have 31K miles on the car, but they apparently replaced the pads and measured the rotors to allow it to qualify for CPO.
Sirius blamed MB for not updating their software and MB blame Sirius for providing poor signal...
The car has been in for the transmission problem and I am assuming that they did in fact reset the transmission adaptation, however since the problem still exists I am hoping they forgot.
Like I said it is my third MB, 2007 E350 was my first and I had zero issues, then a 2008 ML550 which required a new engine after a month of ownership. This wee monster did not require new brakes for 30K or rotors for that matter, that is why I am concerned about my 2011 E550C
2003 SL55; 2008 S550
CPO Re-conditioning
All CPO cars get new pads, oil change, filters, etc. as part of the 're-conditioning'. This is a re-set to get the car in good as new condition, and allows the MB extended warranty. So even if the parts are still good, they are replaced with new.
My CPO had a pretty long list of new parts including floor mats.
S212 220 CDI
Even if the rotors were not replaced since the car was new, it still sounds unusual to wear out rotors at 31k miles.
Agreed, rotors should last longer -- how do you know you need new rotors -- are they warped, are they squeaking/grinding? The pads should not have gone below 10% in 6k miles...
I would keep pushing the transmission issue, and then get corporate MBUSA involved and this will light a fire under your dealership's ass to find a real solution. That's what I'm doing with my 2k14 that's been in the shop for 2 weeks with a bad transmission.
best advice I ever got was to involve MBUSA (new jersey, you can google the phone number, customer care division)
2011 E550C
Discussion Starter · #7 ·
Thank you guys for getting back to me and confirming my suspicions,
I spoke to my dealer and they are telling me the pads were new at CPO inspection, however, the rotors are warped and in turn wrecked the pads. I have agreed to give them $330 for new front rotors and brake pads.
I have explained to the dealer that I do not want the car back until the issue is resolved. A friend of a friend works for Daimler and he had to get involved before when it came to dealing with my old ML550.
The dealer did find the cause of the smell I have been complaining about and it was an oil leak dripping onto the catalytic convertor! And the Sirius unit has already been swapped out, any ideas about solving that one?
BTW, that $330 has cost the dealer a sale of a 2015 GLA for my wife.
Island -
It was roughly, intermittently, downshifting from 5th to 4th gear, and occasional rough upshifts in other gear pairs... the biggest and most prevalent and concerning issue was this rough 5th-->4th downshift
I would have sirius reset the signal -- try that -- do you have any radio devices in the vehicle? I have a baby monitor that uses radio frequency to transmit the signal to the video monitor and that would interfere with the sirius in my wife's Infiniti -- when we turned the monitor off, sirius was perfect, when we turned it on, sirius would keep "searching for signal" and be spotty with the connection. It took a while to figure that one out.
Glad they found the cause of the leak -- guess CPO isn't what they claimed it was -- but perhaps the leak occurred after you purchased the CPO vehicle?
You shouldn't have had to pay anything for the rotors/pads -- but $330 bought you at least 20-30k of trouble free braking .. so that's good.
Whatever car has the gas in it
Do not even get me going on Sirius...
Is this normal?
I have Sirius Radio in 3 of my cars. 2 Mercedes(E350,CL600) and a Porsche(911). The Sirius radio in my W212 works when it wants to. I call the company and they keep saying it is something on their end. The traffic guide works fine, the normal AM/FM radio is perfect and my Bluetooth audio is crystal clear...Sirius? Forget it. I was on the phone for almost a hour and I just gave up on it. It reminds me a lot of Direct TV. I love it when it works!
The sirius in my 2k14 is flawless... wonder if they changed something...
2011 E550C
Discussion Starter · #12 ·
Island -
It was roughly, intermittently, downshifting from 5th to 4th gear, and occasional rough upshifts in other gear pairs... the biggest and most prevalent and concerning issue was this rough 5th-->4th downshift[QUOTE}
Sounds like my issue. It felt like the first time I tried to change gears when I was learning shift 25 years ago!
Keep me informed if you have the time.
Cheers
island -- they're saying I have a defective valve body (a part that it's in the bottom of the transmission case) -- they'll have the part replaced by thursday and will retest to see if I have harsh shifting... will update as we go, thanks for your interest
1 - 13 of 13 Posts
