I would appreciate any suggestions on what might be wrong with my 1992 300D with approx 214k. When the weather turned cold (i.e., <40F), I noticed that the car was delaying shifting upwards (1-->2, 2-->3, etc.), but was fine when it warmed up. It also seemed that if I left it in the garage it would start out shifting reasonably well, but as soon as it got a bit of the cold air around the transmission it started to delay. After about 1-2 miles of driving, the shifting began to improve, and it would become smooth as butter after 4-5 miles.
The gasoline model (300E) has an upshift delay circuit that slows upshifting when it is cold (to warm the catalytic converter), but the diesel has nothing like that. The transmission was rebuilt at 178k, could they have inadvertently installed a 300E transmission?
I recently had the transmission serviced with a complete drain of the fluid and changed the filter, and replaced it with Mobil 1 Dextron fluid. That did not solve the problem. What else could it be? As it is, I can't drive the car in the cold weather (but the turbo works great in the cold).
-Mark HIll
-Mark HIll
