W210 1996 E320 Smoke Silver. [W124 1990 300CE Artic White - Sold].
Results for high speed/low speed:
HC (PPM) 454/445 (Standard = 140/144)
NOx (ppm) 3512/3189 (Standard 984/1077)
According to info sheet the possible reasons are:
- O2 sensor
- EGR valve or hose
- Ignition timing and system (advanced timing and ignition components are some of the most common problems)
- Pirimary feedback sensor failure including oxygen sensor, MAP/MAF, TPS, RPM and CTS sensors.
- Vacuum lines (deterioration of vacuum lines, inlet manifold seats, and become more prevalent causes with age).
- Catalytic converter.
My car has no OBDII how can I narrow down the cause? Is there a pre-OBD device with push buttons somewhere? and why there is no CEL at such figures beyond pass range.
Before the inspection I had fuel system cleaned, I changed spark plugs and coolant.
I've got 14 days to get re-inspected; I'd appreciate your inputs since the spectrum of causes is to wide for me.
- O2 sensor
- EGR valve or hose
