Hi Guys! Trying to fix my airmatic suspension on my 08 ML550. Can someone please tell me where the air tank reservoir is located on this car.
So far I have:
-replaced front airbags with Arnot
-replaces rear airbags with generic ones
-doorman air compressor
-new valve block ordered
-replaced rear struts with ADS
Appreciate any help here.
So far I have:
compressor/reservoir is under plastic inner front wheelarch cover O/S/Front
You are absolutely right. Most parts were replaced as they were visually/audibly defective (extremely noisy compressor, damaged rear air bag and leaky rear strut) but now I’m navigating a bit blindly as the one of the rear airbag is not inflating. I assumed it had something to do with valve block. Since I’m waiting for valve block to arrive I just figured it wouldn’t be a bad idea to check the air reservoir tank which was located between the rear mufflers. I did the soap test to ensure there are no leaks in this tank.
Any recommendations on what’s the most economical way of reading codes on Mercedes?
