I just noticed on my 2005 SL600 that when the front windows are all the way down, they are not even.
If I measure the amount the front window sticks up over the outside door rubber trim in the down position, I find that on the driver's side, the window only sticks up 1/8 of an inch.
If I measure the passenger window in the down position I find that the window sticks up 5/16 of an inch over the outside rubber trim.
These measurements are being taken toward the middle of the window in the down position where it is at its highest point.
I would very much appreciate it if the 2005 SL600 owners would check the following:
1. In the down position, are both your front windows even or does one stick up more than the other over the outside rubber trim.
2. If they are not even, which window sticks up more.
3. And...if they are not even and you don't mind, please measure what the heights are.
Thanks for all your help. I can't imagine they are not suppose to be equal. I know there should be an adjustment for how far the window goes down but I am not sure if they are suppose to be equal and if they are, which one is wrong.
If the windows are wrong, Mercedes will have to find the adjustment screw on the regulator.
Any answers from 2005 SL500, SL55 or SL65 owners would also be very much appreciated.
Again, thanks for your help.
