I've just started searching for a 1984 or 85 300D or 300TD, with turbo and preference on a wagon. I saw a very fine example of a 300D tonight, 206K miles, and many of the same problems I've read about on this board. However, the seats got the better of me. I pulled on the height adjustment lever on the driver and passenger seats and nothing happened. How do you work the height adjustments? They seem simple enough but I couldn't get them to work. Do they tend to stick and need greasing or adjustment?
90 300 SE ,85 300 GD
Seat Adjustment
This was not the best design even when working correctly. You must move the seat forward or back as you change the adjustment to raise or lower the height. Check the owner's maunual for the correct use of the height adjustment bar.
