so i have had my S class 2002 for the summer so far and 0 issues with the aircon, but now when the temperature is dropping im finidng myself having issues
so to go in to detail
when im trying to warm up the car the middle air vent is not on whatsoever (its turned to auto) and the ones in the door is "barly" puting out ANY air at all but they at least are, the defrost vent in the front works and not works at the same time, its the only vent showing air in to the cabin, but its shooting COLD air!!!! also if i turn off auto on the centre airvents in the front they turn on like normal but they are just like the window vent shooting COLD air
this is a problem as long as the system is set to a higher temperature than there is inside aka its supposed to heat. is the temperature is set to less than the outside temperature the aircon turns on and all the vents start up no problem but its still cold as the temperature is set to cold.
meanwhile i have the long wheelbase version and a independent system in the rear and those 2 in the centre for the rear seats is like a tornado of WARM air, in other words the rear vents works flawlessly without any issue
any help with this would be much appriciated
(by cold air i mean like same temperature as outside or maybe 1 degree celsius more but not noticable)
