1 - 1 of 1 Posts
I have a 86 and a 87 parts car...I was having problems with the temp control module on the 86 and swapped out the unit from the 87..are they the same? I see the recirc switch is different but that is about all I can see...but it dosent seem to be working....the connector on the drivers side broke and I had to do some repair with the one from the 87..which has a extra wire..do any of you have a pin out for the wiring?
Also I broke the top plastic piece where the center two vents are...didnt know about that top screw..any ideas where I can get one??
Thanks for all the help...
1 - 1 of 1 Posts
