Jaguar STR-sold,mercedes s500L-sold,c36 amg-sold,s500 coupe-sold,cl420-sold,s320-sold,s280-sold
Hi,
I know there are lots of threads about AC-heating problems,duo valves etc.None of them gives me answer for my problem.
Had a problem before with AC control panel all leds were coming on, only way to switch the unit off was to remove the fuse when car was off.After a while everything stopped to work - panel is on you can adjust temp, fan speed but nothing is working.I bought another unit but it is the same.
Any advise on this please.
W220 S320 CDI 2005; W140 S280 1994 (Sold Nov. 2012)
Hi Borys,
Can you tell us what year the car is and specify the behaviour of the system in more detail.
Mike
It is a 1996 CL420.
At the moment with new control panel.When car started display of the unit seems in order I can adjust temp,fan speed manually put it to auto,etc - all switches, controls seems to be working ok.I just don't have a response from the fan at all.
Thanx
Yes tomorrow will check the regulator.I found an interesting thread with similar symptoms to mine.Will post with results.
Thanx
W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
I had the same Problem like yours , some Water leaked into the Blower fan after the Mechanic changed the Filter there and didnt Seal the Huge Lid over it properly, i blowdried everything under there made sure it is all dry and work't eversince perfect .
Symptoms i had where all Lights work on the AC Buttons Heat/cold etc just no Fan under the Hood,no air activating , (Left Side in behind Firewall ,under black cover ) .
Ciao :thumbsup:
Thank you
