1982 300d 43k original miles with veggie kit
I have a couple of questions but first of all I have been reading on here for a couple of weeks and tried several times to register today it finally worked
1-- I have a 82 300d it does not have a block heater and it is too cold to try to install one can I put in a tank heater and if so which port do i do this at --the one on drivers side by the oil filter or passenger side by the aux pump
2 my car has ero lights and the lenses are bad my wife found several on ebay Germany will these be the same lenses
Daily Drive 82 240D 4 speed
do people really live off these block heaters? i never use mine even into the negatives. run rotella synthetic 5w-40, make sure all your plugs, and battery are good.
i'd check to see how your veggie system works because a lot of systems (grease car included) cross contaminate between tanks during switch over. in this case you'll have veggie in your main tank and that will completely cut fuel to the injectors and you will not be going anywhere till spring.
