1988 560 SEL 2003 Jaguar S Type
When I start the car and get it warmed up, I turn the blower on for some heat. It won't turn on but I can hear like the circulation going thru the heater. Then I leave it on and all by itself it turns on. Any ideas?
'73 450SL, '83 300CD, '01 E320 4matic
Check the strip fuse to see if it's cracked/corroded.. It's located (facing the front) to the left and slightly in front of the normal fuse box, and it's in it's own little black box. Mine (and many others on the forum) had corroded and burned out. I cut the wires back to get past the garbage and installed a 30A fast acting circuit breaker. No problems since.
Aaron
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
Have you tried a forum search? The archive has a wealth of information.
If not sure how, lease re visit the 'Welcome to the Forum' tutorial sticky on top.
Cheers
1982 280 se aut. ecc. - sold
On "auto" the blower will not blow till the coolant is over 40 degrees Celsius.
gr J
