Range Rover Classic Range Rover P38 MGB Roadster 1971, SL500 (R129) 1992
Hi
Does anyone know how to get the heater control wheels lit up? I think it is on here somewhere but I can't find the thread. So helppp please.
Regards
Mike
Hi
Thanks for that but it is the temp control wheels the red and blue ones that control the temp for driver and passenger that are the problem..
Mik
SL-LESS (for now) and 2002 Jaguar XJ8 Executive
Hi Mike, because you spoke about wheels (2) i believe that you mean this unit?
It is necessary to remove the radio, once it is out push the temp unit out from behind.
Disconnect the 2 electrical connectors and take the unit out, at the back you will see 2 white light sockets.
Turn them 90 degrees to the left and remove from the unit, now you can remove the small bulbs from their socket.
Replace for 2 new ones, the right bulb is T 5 (Europe). They are available from 1,2 Watts to 2 Watts.
Good luck:thumbsup:
Hans.
