My heater controls will not change the ouput of air. It heats fine but I cannot control where the air exits. If I have the defrost button pressed it comes out the defrost. If I have the up/down button pressed it comes out the vents with a little coming out the defrost and heater. If I have the down button pressed it comes out the vents. I know it is both vacuum and electronically controlled but cannot find the problem. Is this vacuum system connected to the central locking system? (Locks don't work either) Can I change it to an electrical/mechanical system. Where can I find a diagram for the heater (vacuum and electrical). Thanks Kevin
