Hi, I'm going to tackle the cooling system on my car. First up is the leaking heater hose, heater side of the control valve, under the cover at the top of the firewall. The hose was pretty bad at one end. I managed to get the cowl vent covers off, and removed the other end of the hose from the heater core.
Can you replace this with a straight hose, instead of buying a molded hose from MB? It looks like it might...perhaps I'll give it a try.
Same for the hose from the coolant tank down to the bottom of the radiator?
Looks like the heater hoses at the back of the engine are "fun" to get to, also.
Then...the heater control vacuum valve, of course mine is broken, and I can't tell yet if it leaks because the hose connected to it was leaking. Should I go ahead and put a manual valve here? or one that's operated by a pull cable? I don't expect I'll get the vacuum system working any time soon, it's a complete mess. Everything is disconnected, and finding where they all go is challenging, because most references are to another model of SL, than what I have.
