I am trying to remove the heater core from an 85 300SD. Here is what i have found:
1.) Manuals indicate to remove the retaining screws and core should lift out, reading post at
http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1508647-how-remove-heater-core-heater-box.html
It appears we have the same issue, no retaining bar but shaft that is going to keep everything in. I suppose I have to remove the shaft?
2,) PDF 83-110 point 5 refers to retaining bracket 49. How do you get access to this? My 3 pipes go to the engine compartment under a metal plate that seems sits between windshield wiper and these pipes.
can anyone provide some guidance?
1989 560 SEL, 2005 Acura RL, 2006 Scion xB
I just changed the mono valve in my 89 560SEL. took me about 15mins. are we talking about the same thing?
Thanks for replying.
No, different equipment. The monovalve is located under the hood. The heater Core is located under the dash.
