1989 190e 2.6
hi.
when i got my car i was handed the heater piping and the Auxiliary Pump. now my questions is are this pipes connected correctly.
the second hose from the Auxiliary Pump dose not reach. is this the right hose?
thanks in advance. sorry if its kinda confusing
1990 190e
Let's see if this helps. My pics are:
#1 is the valve
#2 is line to heater core on drivers side
#3 is the pump
Your valve looks to have the correct hose on it in the picture. Your pump does not. The hose does go from the pump to the metal pipe in your #2 and #3 picture. #4 picture take hose from firewall and attach to the back of the engine and remove the long hose. In other words, your red arrows are pointing to the correct attachment points but you need the correct hose for the pump to metal tube coming from the thermostat housing.
Hope this does not confuse you even more.:) (sorry for the fuzzy pics, taken with my phone)
1989 190e 2.6
hey chucky, thanks for the help.
yea when i got my car the pipes had been removed because there was a leak in the heater core witch i am going to replace this week.
ok so i guess ill need to order the correct pipe that goes from the pump to the front of the engine
thanks
