Well that means the auxilary coolant pump is comming on somehow. I am assuming the engi...
Well that means the auxilary coolant pump is comming on somehow. I am assuming the engine is at a higher RPM than normal crusing speed. That is a very odd problem. Might want to check out your alternator and voltage regulator.
Plus side to your problem is that when you drive up a hill you won't have to worry about overheating!
heh heh
