The first day I owned the car, the Heater/AC fan worked. Then I opened up the fuse box to check the sunroof fuse. (roof inoperable.) I checked all the fuses, replaced the cover, now the fan doesen't work. I pulled out the control unit, (connections are good), and checked the fuse box again. Is the heater/AC fan called the "Blower motor" or the "Accessory fan"? In any case, all fuses are intact and there is no evidence of corrosion. I have to think I'm missing something here. Are there any fuses related to the Heater/AC fan outside the main fuse box?
About the sunroof, to manually crank it back, do I just turn the 17mm white nylon nut mounted to the roof motor, or are there any locknuts I should worry about before cranking away on the nylon nut?
