After fiddling with my vacuum system under the hood yesterday to remove some of the things I -know- didn't belong there, and bypass the door locks, I've lost heat to my floor! That flap isn't actuating like it should now, so I've obviously removed one of those vacuum lines too.
I was doing this to attempt to get proper vacuum to my transmission and I succeeded. Turns off with the key faster than it ever has, noticeably quicker. This will let it still drive reasonably while I get the parts for wherever my door lock system is leaking.
What's the color line going through the firewall on my 84 300D that does the air vents? Is it on the same run as the door locks and I'm a fool? Well, I'm a fool, I already know, so I guess I just need to know if it's on the same run. :surrender:
Dave aka Ghan
The green/yellow line is for the HVAC, the yellow/red yellow/green is for the door locks.
Sweet. guess that means I need to clean off more caked on grease/dirt because I didn't see any that were green! ;)
I'll have to do this in the parking lot before I leave this afternoon!
Dave aka Ghan
