1 - 20 of 40 Posts
E-ZGO 53 HP., 99 E 430 sport, 04 E55 AMG, 2008 Tahoe LTZ Sold Porsche to Brother
Headliner Replacement in Alcantera and Roof rattle fix.
Here we have a 1999 E 430 "the victim" due to old age, and major disruption,
the headliner is falling.
I did a roof rattle repair 2 years ago, and that may have caused some of my
headliner problems.
As well I had the windows tinted last summer and after that the headliner fell.
I think the disruption played a part, but the headliner fabric has a foam backing and
that is what deteriorates over time. Touching it or rubbing it will cause it to come lose
before it's time.
First thing I needed was the sun roof door. The forward inside edge has a black plastic
cover that opens the sun roof door when you open the sun roof. It has little tabs on the ends
pry them inward and pull down on the plastic cover to remove it.
Discussion Starter #2 (Edited)
Here I have released the end tab and am pulling the part down.
Here is what it looks like removed.
Now open the sunroof.
Close the sunroof door.
This is one of the 4 sliders that support the sunroof door.
To remove the sunroof door you need to compress the sliders.
Here I use a knife and lift the door up while the slider is out of the track
do same for the other sliders, and remove door in a forward motion.
To remove the vents I bent them.
This is how much you need to bend them to remove, careful.
The door handle just snaps apart.
Now that I have the sunroof door I can take it with me to match the color.
At this point I don't know if I will use OEM fabric or Alcantera, I have priced both,
more on that later when I find the best color match.
Remove the rear lamp and support clip it is behind the lamp.
Open little doors in the handles
Unscrew handles, to remove rotate up, they are hooked in.
Remove sun visors.
Remove the sun visor catches, you only need to remove the screws
the catch is two pieces.
Now remove the lens on the over head lights, you will see the metal
release catch on the over head console.
Release the catches and swing the console down and remove the wires.
Unplug the wires to the rear view mirror and pull the mirror straight
down.
To remove the door seals it is best to remove the thresholds first.
There are two pieces in the rear, see the clip location.
Front door one piece note clip location. Once the thresholds have been removed
you can remove the door bead/seal and mark them with their location.
The "A" pillar has 6 clips that are tight, start by pulling at the top, straight away
from the pillar. Don't use any tool to pry the cover off, there are many wires and
an airbag inside.
Here is a better pic of the angle to pull at.
This is why you should not any pry tool, wires and airbag.
In your OEM tool kit you will have a sunroof emergency tool
to open or close your sunroof. for the next item the roof
needs to be open.
Along the front edge of the sunroof is a channel with a rubber
seal on it, this piece locks the headliner in place. to remove it
pry it straight up.
Now you can release the 4 clips on the "B" pillar, and move
them out of the way. I plan to recover all the pillars "A,B,C"
I will remove them later.
To remove the "B" an "C" panels you need to disconnect the seat belts.
The "C" pillar has 4 clips 3 in the forward section and one in the rear.
once released from the clips pull the panel forward to release the
locking tab in the lower section.
At this point you can swing the "C" panel out of the way.
Next we drill out the pop rivets
Now the headliner is hanging on the rear sunroof interlock.
To lower the headliner it is a good idea to have a helper
one person on the left one on the right. holding the forward
part of the headliner down slide it forward, and in one
inch it will release from the rear interlock in the sunroof support.
Now that it is free you can withdraw it through the front passenger door.
I don't know if that is the best way or not, I did have to give it a bend
like a taco. It is not easy to remove, but it can be done. try to avoid
bending the metal frame around the sunroof opening.
Poof it's out, sorry no pics in process, I had my hands full.
The old fabric comes off quite easily, but the foam backing
is a huge mess.
Once the fabric was removed we cleaned what was left of old
foam and adhesive, took hours to get it smooth. This part was
important because I have decided to go with Alcantera with out
a foam backing so I did not want imperfections to show through.
Sunroof door cleaned up nice.
Here is the first glue, only did the large center part to start with.
This is the adhesive I used note High Temp, it is a contact cement
and requires a few minutes to tack.
Discussion Starter #10 (Edited)
Here you can see I slowly worked the Alcantera in to the couture
of the headliner shell. (glue, stretch, clamp) This was very difficult
because the Alcantera has very little stretch.
Many times I would stretch and clamp the Alcantera over night
just to make it fit better.
Here from the start was my greatest fear, the recess for the sun visors
I glued and clamped right up to it. Then I stretched it and stretched it and
stretched it.
Much to my surprise the rear over head handles fit the contour of
the sun visor, so I used them as a tool and clamped them to hold
the Alcantera in place. (for a week)
To pass the time I started to cover the "A" pillars
went right over the OEM covering, no problem.
OK between my previous rattle repair and this complete removal,
the headliner shell has suffered some damage. The black lines you
see are cracks. I repaired this condition with some fiberglass mat
and west system epoxy.
This is the site of the two metal clips in the aft center section.
During my rattle repair I glued the clips on with 3M 5200 (forever)
when I removed the headliner part of the shell stayed on the clips
so I had to glass over that damage.
Patch over the "B" pillar, This is a natural flex point.
Stretch and clamp the sunroof opening.
Like my tool, I have lots of prescription bottles. So ya, see a
sober person would never DIY a headliner. That is my best
advise.
Discussion Starter #12 (Edited)
More stretch, glue & clamp......
The corner radius in the sunroof opening is all the Alcantera can do
it is stretched to the max.
The forward edge of the sunroof frame requires the Alcantera to be glued
to the underside of the frame.
All most done, time to trim all openings and reinstall forward overhead
console metal frame.
The rear clips were found to be removable, so I pop them out to
remove the old rivets.
Discussion Starter #13 (Edited)
Here we install the metal frame for the rear lamp.
Test fit new hole for rivet
Test fit rivet and clip.
At this point I know that I will not have to do a "do over"
and will now have enough Alcantera to cover the "B & C"
pillars. So to remove the "B" pillar I will have to disconnect
the seat belt from the seat
The "B" pillar is ready to be striped.
Discussion Starter #14 (Edited)
"B" pillar in process
Other panels begin recover process.
TaDa the headliner is DONE and ready to be re-installed.
Other parts all most finished.
Inspection before re-installation.
Discussion Starter #15 (Edited)
OK this is looking at the sunroof and sunroof frame in side the car.
The part with the 6-7 white dots is the frame that causes the rattle.
I put 7 dabs of 3M 5200 marine sealant to fix my rattle it worked and
I intend to use the same method again (headliner glued to frame). If
you look at the rear of the frame you can see the the two clips (gray)
they will be glued to the headliner by same means with 5200. I did
install the headliner but I have no pics yet cause I have a support
in the car to hold the headliner up while the 5200 dries (7 days)
I will post up pics of the finished product and other information next week.
Discussion Starter #16 (Edited)
Well the hard part is done, and for the most part I am happy. No matter how careful you are there will always be a few flaws, the only finishing touches will be, a finish bead at the top of "B" pillar. I used Alcantara only no foam backing so there is a slight gap at the top of "B". and I have not decided what to do with my sun visors, I would like to put some kind of screen, movies on the right and GPS nav screen on left.:nix:
So far so good the Alcantara is holding on the pronounced contours.
I did not take the time to brush the nap one direction.
The color match was much better than OEM could not have been better.
I would like to Thank Joe and Lucy at Gulf Fabrics, Inc.
They are the US importer for Alcantara and located in Tampa FL.
The headliner as depicted here requires 4 yards of pannel.
Contact information,
Gulf Fabrics, Inc.
3709 N. Armenia Avenue
Tampa, Florida 33607-1303
P.O.Box 7725
Tampa, Florida 33673-7725
813-875-2707 local
813-348-9540 fax
800-237-6677
Gulf Fabrics Home Page
[email protected]com
1997 W210 E320 Avantgarde
You have done a fantastic job with the instructions. I am jealous of your work shop. It looks like you have a really good set up. I wish I had the space to attempt this project at home...not to mention the patience.
Drew
'01-E320 & 02-ST2
So what'd that take you, an hour or so? :D :D
Seriously, thanks for the post, as always. There is lots of good information in there otherwise even for those that don't want to pull the entire headliner.
But where is the AM/FM amplifier? :rolleyes:
Take care and enjoy the new 'n improved ride,
Greg
1 - 20 of 40 Posts
