The ML's bulbs are usually 55 watt H7 Phillips. The SilverStars will give you a slightly whiter beam, but probably not too much additional output.bobalvis - 1/31/2005 6:17 AM
What headlight bulbs comes standard on the 2002 ML320? I am considering upgrading to the Sylvania Silverstar and wondered what results to expect. Should I replace both low and high beam bulbs?
Many thanks,
Bob Alvis
I bought silverstars for use in my CR-V when I worked overseas in 2003 and thought they were excellent. The beam was not only whiter but went out a bit further ~10-15%. To get a bit more reach, its better to raise the lamp slightly (not enough to blind incoming drivers though).bobalvis - 1/31/2005 7:17 AM
Many thanks,
Bob Alvis
l have to agree.....l recently changed my bulbs to the Silverstar's.."What an improvement".....night and day difference!!!!l replaced the low and high beams..both H7's..and 55 Watts.....pricey... yes, but worth it!!!!!Airjunky - 1/31/2005 8:07 PM
Many thanks,
Bob Alvis
