1 - 14 of 14 Posts
250D Sportline (W124) from 1991
Hello,
Today testing my car lights when pulled the headlight switch in order to turn on the fog lights the switch just came off.
Now I can't tirn fog lights on as if I pull the switch it falls off.
Please see photos:
What should I do?
Do I have to buy the full set of headlight switch bezel or just the switch?
p.s. sorry for my english
You can just buy the plastic knob from the dealer if that is all you need.
great new. thanks a lot friend.
I thought I needed to replace all that set
I order the part already:thumbsup:
'89 W124 300CE signal red, AMG body kit, 17" aero 1's, bilstein and AMG springs.
I had this a week ago too. That is all.
1988 "Zender" 300CE Coupe, 2009 Renault Koleos, 2007 Kia Rio Sport
Plenty of them via fleabay. Unfortunately they have a shitty design with the globe and holder inside the switch and it crumbles with age. Do you still have these exposed ?
Stormy Tiger's iPhone
hello,
its not exposed.
that part is there and i can turn the lights on.
but if I pull the thingy, say to turn on fog lights, it just pop off and I keep it in my hands.
Well thats good. Mine had crumbled into aillion pieces and tbe very thin wire was broken off, a replacement knob should do the trick fine !
I have ordered mine and I'm waiting for it.
Just noticed that the light from the knob that controls the air vent is off.
Neeed to replace the little led.
Do I just pull the knob until it comes off or to access that light requires something else?
Current, 90 300CE, 92 400E (Sold 95 E320,70 250C, 91 190 2.6, 91 420 SEL, 95 300D, 87 TD)
Hello,
Please see photos:
What should I do?
Just try to put it back on for now until you get a new one. Mine was worn out too and came off real easy, so I got a good one from a junk yard. Be careful though don't force it.
thanks a lot for all your help guys.
Meantime the light on the knob that controls the air vent gone. I need to replace it. This knob is fixed the same way, therefore in order to change the little lamp inside I just need to gentle pull it off?
Do a search on the top right of the w124 forum foe vent removal. There is a lot of older topics on this and is a little more involved than pulling on them.
Yeah Sam you need multiple sharp pointy objects to lift up those little catches inside the vent etc
Discussion Starter #13
light switch knob has arrived, fitted already and working great ;)
Thank you all guys
1 - 14 of 14 Posts
