21 - 26 of 26 Posts
04 odyssey (265k) 1995 E320 wagon (295k)
Lower harness was in response to the no start issue. Does it spin but not fire, or nothing at all.
1993 300E, 1995 E320
Discussion Starter #22
The car turns over but, doesn't fire. I am waiting on a fuel pump relay and OVP relay.
Be sure to check resistance on the crank sensor as well. A out of spec crank sensor will disable the ignition system.
Discussion Starter #24
New OVP relay and fuel pump relay and the car started right up. I still have some electrical gremlins but, at least the car starts and runs now. I think maybe messing with the taillights may have damaged the OVP relay.
i wonder what happen to this gremlin.... i'm having the same situation... i pull a relay (mutl. relay ) from junk yard, left side now work ( standing tail light / running light ) now work, but right side don't, so may the relay i got is still is also bad... trying to get a new one from the dealer in next few days.... i'll see if that will solve this problem.. other wise i will be out of few $$$$$$ ....... l
1994 SL320
Look at the wiring diagram it'll have the pin info. Use a jump wire to prove/disprove an ecu fault.
21 - 26 of 26 Posts
