headlight problem
2.5K views 5 replies 2 participants last post by  cowboyt
I have aftermarket (Eagle Eyes) headlights in my 2005 E500. After a few years the P/S one would only work (when it felt like it) so I bought and installed another. The dim and turn signal wouldn't work so I started trouble shooting. I took the bumper cover the rest of the way off and hooked up the working D/S headlight on the P/S. Now the dims don't work on either side even after switching them back. Headlight fuse (66) and bulbs are good. Googling around I found mention of a SAM (signal activation module) causing headlight problems. What is this? Where is this? Can I see and touch it or can I find it with a code reader? Please help. I don't want to take it to a shop.
The SAM is the computer that controls your headlights and a bunch of other things. Actually, there are two SAM's up front, one for the left side, and one for the right side. If the SAM detects a problem with a headlight, it electronically shuts down power to that lamp's circuit. Best thing for you to do is hook up a STAR Diagnostic System (SDS) or similar--basically a good code reader--to it and clear those codes. It ain't like the 1990's-era Honda Civics where you connect it back up and it works. Computers control all this stuff now.
Just a note: Eagle Eyes are made in Red China. Depo headlights are made in Taiwan, which nowadays is way better, so I'd consider the latter if you can.
owns 2003 Mercedes-Benz S600
#4 ·
They're good cars, no doubt, and that drivetrain will last you until well after after the cows come home. :) This should be an easy fix. Do you have halogens or HID (xenon) headlights?
#6 · (Edited)
Oh, then this this should be an easy fix.
On the subject, I would suggest you consider the HID upgrade. That's exactly what I did with my E320 CDI, and the improvement is stark. I'm in a suburb where there are plenty of deer, and I love this upgrade. Since this was a factory option for the W211, it's totally legal to do it.
Here's the post describing it.
If this catches your fancy, then there are two ways to do it.
1.) Open up your existing headlamp assemblies and do the conversion. That's what I did with my factory MB halogen assemblies, though I had to do a lot of wire insulation repair. The wire insulation used in that era is crap; it crumbles and flakes off, so I had to fix virtually every wire. Took me a while, and I wouldn't do it again. Your Eagle Eyes assemblies might be friendly to this; I don't know.
2.) Pick up a new set with the HID upgrade already in them. I believe Depo actually has this option for their W211 assemblies. If you go this route, don't buy 'em on FleaBay or Amazon; too many counterfeiters. Go to an actual authorized dealer and get the real thing. For our four W220's, I got ours from Unique Style Racing, which is an authorized dealer.
