2000 c-280 (W202 )
My driver side head light low beam only works when i turn car off and close the door. Then and only then it comes on like it should for about 30 seconds and fades off. so I know it's not the bulb.
1998 C230
I want to bump this because I started having the exact same issue today. I'm going to replace the bulb, then fuse and hope it's fixed. If I still have issues, I hope someone has some insight on what could be causing the problem.
'98 C230, '08 C300
It's actually the foglight that comes on when car is off & you open the door (at least sure looks that way). Be certain you check for the correct bulb. Foglight is when you pull out (not turn) the lightswitch one notch.
