82' Euro 240D 84' 300D 01' SLK320 6 Speed Sport!
I cant get my passengers low beam to work..(High beams work fine) No I am not a noob, yes I changed out the bulb (New H4's). However my fog lights dont work either. I checked and replaced Fuse No#11 which is the fog and passenger low beam and they are still not working. Is there a fog light and low beam relay somewhere I didn't check? Thanks
1984 300D
I don't see any relays in the schematic for the headlights and fog lights. The HI/LO switch feeds fuses F13 (left side low beam) and F11 (right side low beam and fog lights). If the drivers side low beam works, then that means that the HI/LO beam switch is working and, so your problem is after the HI/LO switch. If the fuse F11 is good, then you will need to start checking for voltage. Can you measure 12 volts both before and after the fuse F11?
All very good points, I'll get out my voltometer as soon as it stops raining, thanks so much, I'll go from here.
