99' ML 430
I was installing my new 2002 headlights today and got down to the last washer/bolt and tightened a little bit too much and broke off the end of the mounting screw.
It looks like its painted on to the frame. I was wondering if anyone knows if I can just pound that through and get another screw for that mounting point and washer/bolt or what.
Thanks in advance guys!
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Did you break the bolt that is holding the top of the headlight assembly or one of the two stationary studs below the assembly?
- RODNEY
99' ML 430
Sorry, I should have clarified. It is one of the stationary studs at the bottom.
Any suggestions?
I don't recall offhand how it’s attached, but if it’s spot-welded, you should be able to cut it off flush, drill it out, and replace it. Of course this would require a new spot-weld. If you don’t have the equipment to do that and don’t want to pay for it, then you might be able to use a carriage bolt in its place.
- RODNEY
