Since we all are aware by now just how insane headlight housing costs are, and that nobody makes/sells replacement lenses....
Does any one know of this style being used on any other models?
I can never find any threads on this exact issue but from just quick observation, it would seem as if the W211 used the same housing.. Is this correct? Has anybody tried this swap beit the entire assembly or just freshend up the face with new lenses???
Online is littered with tons of aftermarket setups for the W211.
Lmao anyone???
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Welcome to the forum @Thoroughbredzzz - please take a moment to read the information on the links below. It explains how to use the forums and update your user profile so that your car's details and your location appear on each post below your avatar. This is good information for others to know when trying to help. It also has good information about how the forums are organized and how to use the search feature:
Find your Forum Section, Navigate & Search
Complete your profile.
00' E320, 03' E320T, 05' C230K
Lmao anyone???
The headlight housing for the W211 and W215 have different part numbers. I would assume that they are different and not interchangeable...........at least without modifications.
CL600 '00 5.8L V12
Based off my quick google search, they won't fit. The main headlamp section of the W211 seems to be slightly tilted compared to the C215's one. The little headlamp region is also lower on the C215's so that won't fit
