'80 500SE AMG '80 300SD '78 450SLC '00 Passat GLX Wagon
The lenses on my 500se are really dirty and fogged inside. Can I take them off and put them back on or do I need to install a new set once I remove the old ones? Also is there a difference in the quality of replaement lenses? I've seen them for $60 each up to $75 each. What about the clear side markers, those I have seen range from $50 a set to over $120 a set. Thanks, this place is quite the inspiration to get all the little, and big, things fixed on my cars.
John
'80 500se
'80 300sd
SLK55 (2006) C36 (1995)
I take it you have the euro headlights?
supposedly they are removable, but between certain years, they glued the lenses on, so you'll have to take a look at what you have on the car (unless someone knows which years they were).
cyberdrakon - 2/8/2005 12:31 AM
Thanks,yeah they are euros. I'll take a look and see but they will need to be replaced someday so maybe I'll just order the news ones anyway.
John
'80 500se
'80 300sd
Smoke Silver '87 560SEC, Black Pearl '87 560SEL
Euro headlight lenses are replaceable and are about $50 each. Take the headlight assembly out of the car and the clips that hold the glass in place are readily apparent. Simple job.
Very Black 86 420sel
I think that Jonathan sells them a little cheaper than that. Sorry Jonathan, I don't want to put words in your mouth ;-).
