Hi all,
I am new to this forum. Need some help with headlight adjuster on my B180 (2006 reg, UK registered).
Headlight on driver side won't adjust the level when I change the level adjusting thumbwheel near steering. Passanger side works well.
Is there a motor that adjusts the headlight beam height or is there some other mechanism that controls this. (MOT on the car has failed due to this fault)
Any help would be highly appreciated.
see signature
If it's anything like the one on my smarts, it will be a motor. The Canadian versions of the B-Class don't have this feature.
W123 '83 200, W210 '98 E200K, W212 '13 E350
M-B has often used a vaccum operated adjuster. Make sure it's nothing simple like a disconnected or broken/cut/leaking hose to or at the light assy....maybe caused from working nearby or a collision or similar.
Sent from my Galaxy Nexus using AutoGuide.Com Free App
