Geez the car was working just fine until I notice the headlamp switch a pain to turn on the headlamps and foglamps. Its a 95 c220, anyhow when i go to start the car at night the headlamp switch is not turning none of my lights on. Is this a common problem for this switch to fail. Its difficult to turn also.
96' C220
Witch Switch...
Sounds like an internal mechanical failure. I'm sure you have already checked fuses etc.
I've not heard of this before but maybe a search would reveal something.
Good Luck!:thumbsup:
C as in 220
2006 C55 AMG
check if your ebrake pedal has been pushed in a little bit, that will not allow the head lights to come on if you might have pushed it accendintly. Other than that just like what cjshade mentioned it could be the fuses or maybe your hole fuse box could be fried. Does your stereo, horn and wiper etc. stil work?
