Alright, just to clarify here... The upgraded socket eliminates both contacts within the headlamp housing. It costs a little over $40 dollars with tax directly through the dealership. I went back to the dealership after noticing there is a special tool used to un-pin the female wire contact from the wiring harness. The SLK 2.8 Blade, and Blade Holder will run you nearly $100 dollars! So, you're left with only two options, right? Either have the dealership install the upgraded socket for around $50-$100 dollars, or purchase the $100 dollar special tool, which will also have to be put on order. Takes a few days to get into the dealership...
Don't even think about asking the dealership to just remove the single wire real fast with their "special" tool, because the service department will just make you feel like a worthless idiot, and tell you they can't do that. I complained to the service manager about how I always get treated by these service jerks, and he said their attitude would be adjusted... He was even kind enough to recommend a shop that would remove the single wire connector real fast for free.
Of course the guy was backed up with work orders though, and I couldn't have him do that until Monday. Didn't feel like waiting, and being the type of guy I am it was decided to make a custom tool... Took about an hour of messing around to create something that worked perfectly. Plan on making a DIY thread when I get photographs, so I'll let you all know what I did later... I made the perfect set that replaced their $100 dollar tool for around $2 dollars.
