I have Mercedes A160 since few days high beam of my car have some problem like getting off itself or it does not get on at once. I have to make the switch 3 or 4 time on and off and then it gets on but today high beam is complete not working. Is it a cable problem or bulb or switch problem? I have no idea about it. Can any one help me what should I do before I send it to work shop?
Outstanding Contributor
A200 Sports Coupé C169 2006
Hi Rafana,
Welcome to BenzWorld :)
The issue could be a few things:
Bulb
Wiring
Fuse
Light Switch
There's a secondary fuse box in W168 - on the side of the dashboard (on the right for RHD cars, not sure about LHD ones) - the cover comes out easily and you can visually inspect the fuses.
If these are fine, check the bulb.
It gets a bit more complicated after that, but if you want to, I can pull workshop instructions files on light switch removal and wiring diagram for your car (let me know first six digits of the VIN, i.e. 168xxx).
