'91 300SEL W126
Hey All;
I removed my M103 head to get a valve job which looks pretty good but now I decided to pull the engine out and rebuild the entire thing seeing its already at 250k mileage.
Now here is my question... although I think I already know your responses... is there any way to pull the engine out WITHOUT putting the head & top cover back on? The engine hoist (suspension) eyes are of course on the head/top cover. I was hoping you experienced guys/gals just may have a work around for this particular problem? Since I have already rounded out a head bolt & now have to wait for that special order to come in I really wanted to proceed with the engine pull if at all possible.
Again, thanks for all the help
Rick L.
ps. the head bolt came out easily.
300se, 560sel
Did the same exact thing. Wrap the engine with chains. I used the head bolts and inserted them back in with the chain in-between. I too had 250k and just rebuilt everything. I don’t trust those mounting eyes, just look at the bolts that they attached to, scary! You won’t regret rebuilding this puppy. I would use genuine parts at all the critical areas i.e. headgasket, hoses etc etc. Also locate some Reinzosil and used it at all the oil leaking prone areas.
Rick
W111 Coupe
Insert two head bolts (with a big washer if necessary) in chain links, one at each end of the chain. Then screw the two bolts at each end of the block deck and your engine is ready to be lifted.
2012 CL550 4MATIC Coupe
+1 ^^
W111 Coupe
If you want to reuse your headbolts and fear to damage them just use other(shorter) bolts with the same thread
