Hi all,
I've decided to attempt changing the head gasket on my 95 C220, I've got my hands on a service manual and got all the parts and tools I need.
I was just looking to get any tips or hints to make the job go smoothly?
Cheers,
Tom
Sent from my iPhone using AG Free
2000 C230 Sport
Take pictures of everything as you disassemble, mark lines with masking tape/something as you disconnect, and put like bolts (IE valve cover bolts) in seperate ziploc bags with a label of what they go to inside the bag with them.
1995 C220
I am working on same project. Everything has gone pretty well except for wiring falling apart. I guess I will try splicing, can't afford the harness, or don't think the car would be worth investing another grand with 275,000 miles. So, I would say not to unhook anything "wires" that is not necessary, and try to avoid the wires altogether.
Its almost together, one other problem that I am worried about that is due to a momentary loss of geometric skills. I some how convinced myself that 90 degrees was 1/2 turn, therefore when torque the head bolts I went a total of 1 turn past torque value, not the 1/2 turn I was supposed to do. Now I really don't know if it would be better to loosen the head bolts and redo or just leave as is. Anybody have an opinion on that?
