I'm beginning to think more and more that my coolant issue is head gaskets, but before I rip hald the engine off I have some questions:
1. What are some determining factors or telltale signs that a head gasket has failed?
2. Should I even try to do this myself or bite the bullet and let a shop do it (I have built performance engine before - Chevrolets though)
3. In regards to my coolant issue, I changed the pressure capm on the coolant bottle from the high pressure mercedes cap to a generic 7lb light cap. This has improved the amount of coolant loss under normal conditions, is this a sign of gasket failure or another problem in the cooling system?
Thanks much,
Dan
Thanks much,
Dan
