1 - 18 of 18 Posts
91' 190E 2.3L 8V
Hi all, I poked a small hole, 1/10" in diameter, on the head cover..... I wonder how I may repair it. What's your suggestion? Thanks.
W201, W202, W203, W204, W205 Moderator
Amethyst 2001 C320 with 351,000 miles
Do you mean the valve cover?
If so, I'd just put some JB weld or metal epoxy on it. Make sure to take the cover off the car and clean it up really well first so that there's no oil where you do the repair. Then sand it down and touch it up with some high-temp black paint.
91' 190E 2.3L 8V
But do you think epoxy might 'melt' at such high temperature? Will I loose oil pressure if there's a hole?
Okay, I think I will just go with JB Weld, since it withstands temperature up to 500F.
1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
You have an 8v, those can be found in copious JY's the valve cover can be generally pretty easy to come by.
IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
i agree with kynyption, its an 8v, not worth the time, just get one from a junkyard.
W124 300e
how do you poke a hole into a valve cover?? there pretty hard.
IR MODERATOR
didnt think of that. but yea how do u do that ? were u drilling too close to it or something?
Super high powered BB gun trying to hit a fly is my guess.
IR MODERATOR
ive cracked one before but never poked a hole in one.
91' 190E 2.3L 8V
Discussion Starter · #10 ·
Okay, since you guys are curious..... here my embarrassment goes... Well, I was trying to remove the airbox damper that screws into the valve cover. But the rubber ripped right off, left with the metal part screwed into the cover. As I was trying to get under the metal to get more leverage with a screw driver, I poked a hole there with a hammer. There you go...... sounds stupid. Since the hole is small, I'll just JB weld it for now. In the future when I get a valve cover, I might paint it first before swapping.
IR MODERATOR
did u ever get the thing off? i am gonna paint my valve cover and i was wondering how to get it off. i actually have a spare valve cover to play around with.
91' 190E 2.3L 8V
Discussion Starter · #12 ·
Nope, I didn't get it off after I poked the hole. It's because the hole and the damper are so close that I might end up punching a bigger hole there. I think to remove that, you might have to take the whole cover off first, and twist off the damper from the inner side, if there's an access (I've never seen the underside, so don't know). Otherwise, I will leave it on for good, and put some epoxy to glue that ripped rubber back.
For what it's worth, the next time you have your valve cover off, you might as well replace your camshaft gasket, your lower front timing chain cover gasket, not to mention the valve cover gasket as well.
IR MODERATOR
theres a camshaft gasket???
W124 300e
yea, at the end of the camshaft. i have one and its leaking a little. i get some oil in my distributor so i gotta change all that shit soon
IR MODERATOR
i think it only applys to the 2.6's.
1 - 18 of 18 Posts
