1991 300TE
So just as I thought I had caught up on all the little stuff that needed doing - my hazard warning switch has stopped working.
Everything else electrical works fine. I just replaced all the fuses with new ones - about a month ago.
I did replace the Ignition Barrel and was wondering if this plays any part in the Hazard Switch - function ??
Figured I would ask if anyone has had this issue or can recommend where I go looking before pulling the dash panel apart to replace the switch. It functions fine (ie - clicks on and off no problem) - it just doesn't do anything.
Is there a relay or such I should hunt down first ??
Thanks - Chris..
Way too many
Thanks - Chris..
Hello Chris:
I can't help you track down the problem but if you need a switch that works perfectly I have an extra one.
PM me if interested.
Ron
89 300E; 00 E320
-Hazard 127
N10 Combination relay (turn/hazard signal, heated rear window, wiper motor) Rear of fuse box, position H
