1 - 1 of 1 Posts
1993 S600 coupe (RHD)
hi folks,
2 problems, can you advise?
1. should there be an illuminating light on the hazard switch when lights are on? all other switches lit up but not hazard switch
2. is it possible to repair a rear window demister when it has broken heat lines in it? the bottom section of my rear window seems to have white areas where i guess it has de-laminated and seperated a bit so damaging the heat lines.
thanks in advance.
1 - 1 of 1 Posts
