Classic 92 190E 2.6
I am thinking about buying sheepskin seat covers and arm rest cover for my 92 190e. I have had them before for another car and they do work good in the cold and in the heat. But there are so many companies marketing them, I want a good fix at a good price. Any experience?
'96 sl500, 87 300td
I have install several sets.
You will have to cut holes for the headrest shafts, I use an exacto and cut small "X" at each hole.
Drivers door you will have to remove the seat back rest cover and remove the arm rest. Real easy just a large bolt on a threaded stud. Again you will have to cut the seat cover to reinstall the arm rest. putting the seat back back on after you installed the seat covers will require a little fittling, place the seat back full forward, pull the seatcover up as high as possible and wiggle the seat back back into place.
Very comfortable in winter & summer.
Tom
current
96 sl500
87 300td
87 190d 2.5 turbo
previous
84 190d 2.2
79 240d
71 300sel 6.3
69 220d
65 300se
