My left window goes up and down more slowly than my right.
I think I found the source.
Left motor - I separated the top electrical part from the bottom gear/cog part - with the lower part separated the gear can be turned by hand but with difficulty. The top electrical part has the spinning shaft which drives the plastic wheel in the lower part which as it turns, turns the gear. I presume the overall motor is under more pressure as it drives the resistant cog. It goes slowly.
Right motor - When the top electrical part is separated the gear almost spins by hand, moves freely. I presume the motor is under less pressure because there is no resistance in the cog. It goes less slowly then the left motor.
The question is, has anyone dismantled the lower part of a window motor to get in there and lubricate the internals? How is it done?
thanks for listening
Darragh
Darragh
