1 - 14 of 14 Posts
E220 CDI StationWagon w211 10/2003
Hi
I need help please.
I have E220 CDI Kombi W211 of 2003 year and have install a headunit audio 50 APS cd navigation i have too the sound-system harmon/kardon LOGIC7 surround.
My question is:
If i upgrade the 50 APS for a comand this headunit is compatible with harmon/kardon LOGIC7 ? or not?
please help me because i will buy an headunit dvd comand + dvd drive navigation but i like very much the sound of harmon/kardon LOGIC7 and I do not want to be without it.
Volvo 940GLE, GMC Suburban, Infiniti I30, Toyota Prius, VW GTI, MB SLK350, Lexus IS250
The HK/Becker Logic7 is in the AGW (audio gateway) box and not in the HU. The Nav processor is in a separate box and not in the HU either. Your current Nav processor should be DVD based already and in the trunck. The Comand HU is just a display, keyboard plus a DVD player. The MOST ring master is actually the AGW and not the HU.
As each piece may be different with locality, you need to add locality info to you profile so people can see and help with advice.
My locality is Europa-Portugal
Sorry but i don't understand your explain because i don't have any DVD drive. The audio 50 APS is HU with Nav and is not an simple display.
I insert the CD disc of Navigation on HeadUnit.
I wont upgrade to comand HU and DVD drive but i need to know if can conect my HKardan system-sound
The Harman\Kardon work or not with command DVD headunit for my w211?
Comand HU do work with Logic7
Very thanks for your information. I will buy Comand Navigation + DVD drive for my W211.
Do you know where the AGW (audio gateway) is locate on my car? I need same special to install the headunit or is pre-wired to install de DVD drive in rear.
My car is E 220 CDI StationWagon Advangarde. of out/2003 year.
Discussion Starter · #8 ·
hi
I need help please.
I will retrofit my Audio 50 APS for a Comand HU and DVD-Drive Navigation.
I have read lots of things but i don't understand.
I attached same pics to more easy help me.
1º on pics of AGW what are the connections?
1- Optical cable
2- ?
3- ?
4 - GPS antenna spliter
5 - ?
What i need and how to connect power cable for Drive Navigation?
What parts number it is?
I have instaled on car:
Audio 50 APS with CD Navigation on HU
Nokia 6210 conect to HU
Cd-Charger 6 disc
and AGW with Harman Kardan sound system logic 7
AGW connectors:
2. IF connector
3. Antenna connector (for radio)
5. The wires are CAN Bus high and low. Pink is MOST wake-up bus and yellow is Mute bus wires.
US spec Audio50 doesn't have navigation. So I cannot comment on your particular Audio50's Nav functionality. For the US, Nav processor requires Comand HU.
My Benz: 04 S430
CalifSLK said:
AGW connectors:
2. IF connector
On connector 5 on the US W211's there are only the two orange MOST wires, and the Brn can wires.
MOST doesn't use a wake-up like D2b does. So I don't know what the pink and yellow wires are for. They do not appear on the US w211 AGW connector.
Sorry, I don't have a W211 car to confirm what you said. But from my R171 and MB literatures, MOST do use Wake-up lines and normally Pink color wires.
Discussion Starter · #14 ·
Hi
For my car( european car) what are the parts mumber to conect the DVD Nav on rear SAM.I have the AGW on trunk
fibre optical=?
Wiring power=?
GPS antena conector=?
Bracket mount for dvd drive=?
and aux input for comamd=?
1 - 14 of 14 Posts
